Saltar al contenido principal
Anunciado el 16 de octubre de 2014, el iPad Air 2 es un sucesor más delgado del iPad Air.
Preguntas 453 Ver todo
Why is my iPad keep turning off while charging at 1%
so my iPad is dead, and I charge it. every single time when it hits 1% it start the ipad. and then it just turns off because the battery ran out. and then when it charge to 1% it just goes in a loop
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
It might be simply the battery worn out and doesn’t take charge anymore. Make also sure you’re using the right charger, a 1A charger as that for the iPhone wouldn’t be enough to charge an iPad flat battery. Both possibilties would produce the symptoms you’re describing.
Fue útil esta respuesta?
Puntuación 4
1 comentario:
Thank you! I was using my iphone charger to charge my dead battery ipad, which wasn't working. Got my problem solved.
- de
Try powering it off quickly when it turns on, and wait a little while before finally turning it back on. Your iPad should now have more charge to keep working
Puntuación 0
1 comentario:
How can I identify which cable/charger came with my iPad?
- de
Añadir tu respuesta
Blockcity 4k estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 48
Ultimos 30 días: 226
Todo El Tiempo: 13,573
