Green light not coming
When I on the TV green light does not appear on the TV the adapter works the red lights on but not the green light on the tv
Es esta una buena pregunta?
Krishnan S you’ll have to remove the back from your TV first. Then measure the power supply outputs. Let us know what model your TV is and what voltages you get when you check your board. For now this can be pretty much be anything. The red light should mean that your TV power supply has standby voltage so you need to check the rest. Once you have the back open take some good pictures of all of the boards so that we can see what you see. Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 5
Todo El Tiempo: 50
