Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación para el HP Compaq 6910p.
DVD ROM removing problem
How to remove the DVD ROM from HP Compaq 6910p
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hi @elishaalfred ,
Here’s a link to the service manual for the laptop.
Scroll to p.54 to view the necessary pre-requisite steps and then the procedure to remove the DVD drive.
Fue útil esta respuesta?
Puntuación 1
Most times, it is only one screw on the bottom of the laptop and the DVD/CD drive can be pulled out.
Lay the laptop down on its backside to expose the bottom case. There should be a screw with a symbol next to it that looks similar to a CD or DVD or disc. Remove this screw, press the eject button to the left of the drive, and the DVD drive should eject and slide out easily.
Puntuación 1
The following is a teardown for your unit:
https://www.youtube.com/watch?v=HP2_-_13...
If you are trying to remove a stuck DVD disc rather than removing the entire DVD drive, most drives include a manual ejection with a paper clip via a small hole on the drive's front panel.
Puntuación 0
1 comentario:
@propman Right on. I wasn't thinking of that. If the disc is stuck, you will need a paper clip to manually eject the disc with the small hole on the front of the drive.
- de
Añadir tu respuesta
Elisha estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 1,164
