Why is my blaze on constant vibrate
My Blaze is constantly on vibrate. It happened in the middle of the night and will not stop.I put it on the charger and it is still vibrating
Es esta una buena pregunta?
Alvaro, the Fitbit Community Manager, suggests performing these steps:
Press and hold the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen. This should take less than 10 seconds. Then, let go of the buttons.
If your tracker doesn’t work normally, turn off your tracker manually by performing these additional steps:
Try this 3 times in a row.
Also if you have any alarms please deactivate them and sync your tracker.
If that doesn’t fix the issue, then they ask that you contact Fitbit Support here.
Fue útil esta respuesta?
Buttons aren’t working either. Worst watch ever.
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 841
