Sony XBR-65A9F 3 Blink/Flashing help
My second hand (aka no Warranty) XBR-65A9F OLED goes into standby with a 3 blink fault. The 3 blink fault is either a power board or the mainboard failure. I’ve replaced both the mainboard and the power board. I know I’m supposed to do a software update on the mainboard, but I can’t get it powered on long enough to apply the update. Tv will boot to the Android boot screen then click off with the error code. I’m frustrated because I can’t get this thing up and running. Any help is appreciated.
Here is a pic of the power board that I replaced; mainboard is below the power board.
New pics from today’s dive into the A9F.
New pics from 7/31/19:
Es esta una buena pregunta?
4 comentarios
Hey did you ever resolve this, I’m having a similar issue, my light is blinking 4 times, changed t-con board, still 4 blinks, could it be the power board?
- de ronald williams
I have the same issue with a KD-55AF9. I have replaced all boards in this t.v but still not working.
It’s frustrating without a service manual, but trying haha.
I had a Green/Orange flashing light after I replaced the t-con and tried to update via USB, but no activity at all.
Hope you fix yours.
- de Dave
Wow...Dude did you ever get your XBR-65A9F working? It's like almost 2 years since your post. I have the same TV, won't power on and after a few minutes I get 8 blinks on a red LED. Got a CPU board coming but based upon your situation, Im thinking it may not change anything. In for a penny in for a pound? I might have to walk away.
- de Brad Short
@Brad Short I actually chatted w/Sony support and they sent a tech out (My Cost) to swap my CPU & TCon boards. The tech ended up breaking the connector at the end of a ribbon cable and Sony ended up swapping the TV out for a 65” A9G. Apparently, the ribbon cable he broke came from the panel itself and couldn’t be replaced. Two weeks later, Sony had the 65” A9G delivered and I’ve watched it ever since. I have hope for your CPU swap, I was told by Sony chat the 8 blinks is due to a failed software update…keep me updated as to how the swap goes.
- de Jeffrey Buckner
