Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
El receptor Kenwood modelo KR-V7070 es un receptor de audio/vídeo producido por Kenwood Corporation, una empresa japonesa que diseña, desarrolla y comercializa sistemas de audio para coches, sistemas de audio personal y doméstico de alta fidelidad, equipos profesionales de radiocomunicación bidireccional y equipos de radioaficionado.
Where do I get a replacement fan for this model?
Where do I get a replacement fan for this model? I just got it from a Goodwill all the connections work and it set up but the fan is not spinning not sure if it kicks on automatically when it once or it's just not working
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi,
Disconnect the power from the unit and then disconnect the fan and use an Ohmmeter to test the fan motor to check that it has continuity. Also check that the fan blades spin freely when operated by hand.
If the fan motor is open circuit then the Kenwood part number for the fan motor assembly is T49-0025-02. A quick search online using the part number, gave no results for suppliers. You may have better luck.
Are the any markings on the fan itself, such as make and model number which may be of further help (if it is not made by Kenwood and has no markings)?
If the fan motor tests OK with the Ohmmeter, then here’s a link to the service manual for the receiver which may be of some help. Clicking on the link will download the manual directly to your computer.
There is a protection circuit for the fan which you can test to see whether it shows that the fan is OK or not.
Here’s an image taken from the manual that shows this.
Imagen
(click on image to enlarge for better viewing)
Fue útil esta respuesta?
Puntuación 2
It can be hard to find a fan specific to a model like that. But usually amazon is a good place to find that stuff,if you search google with the model number,find the part,and use amazon to buy.
first,you can take it apart to make sure the fan isn’t just stuck. I got an old laptop that had a stuck fan. I took it apart and used a screw driver to unstick the fan(no idea how it was stuck),and haven’t had an issue since then. Maybe a drop can do this?
now,you can use a multimeter to measure the voltage at the pins to see if it’s trying to get power,without the fan connected.
Puntuación 0
Añadir tu respuesta
Patrick Phillips estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 621
