Replace the small black tap on the back
Gear Sport, Blue'''
MODEL NUMBER: SM-R600SERIAL
The black tap on black is gone. Need a replacement? Can anyone fix or can I order this part? Thx
Es esta una buena pregunta?
Gear Sport, Blue'''
This is the only replacement that I could find.
https://rounded.com/samsung-gear-sport-s...
If you do not have one, you will need a tri-wing screw driver. You will also need a splunger or a guitar pick or playing card to pry the back open once you remove the screws.
Here is a simple tear down guide for the Samsung Gear Sport.
Hope this helps. Good luck.
Fue útil esta respuesta?
This is wonderful..thank you, thank you, thank you! I have ordered the back and screw driver and I am sure I will check out the guide once they arrive!
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 186
2 comentarios
It's not clear what part you are looking for. Can you provide a picture showing more detail? Thanks.
- de Joshua Freeman
Picture was added for clarity.
- de Lyn Hardway
