Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
{A1706 / EMC 3071}—Lanzado en junio de 2017, este MacBook Pro de 13" cuenta con procesadores Kaby Lake de hasta 3.5 GHz Core i7 con Turbo Boost de hasta 4.0 GHz.
Why my touchbar have a purple tint around the icon?
Imagen
I have an MBP 13" 2017 , which recently started showing a purple tint around the touch bar icons. It looks there is some sort of issue with it, as at times it just fades and flickers. Every function on the touch bar works as it is supposed to but there is some kind of issue with it.
I have tried booting in safe mode, resetting SMC, NVRAM but the issue is still there. Finally, after a few chats with Apple support, I completely wiped out and did a fresh install of the OS. And after everything, the issue is still there. So it looks like it is some sort of hardware related failure.
Es esta una buena pregunta?
Puntuación 3
2 comentarios
Having the same issue on just 15 days old machine. I got 16 inch MacBook Pro on 6th January 2020 and experiencing the same issue now.
- de
@Erick Bassan - Time to visit an Apple Store or authorized service center
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I’m not very familiar with touchbar build, but I’d say you’re definitely right, looks like a hardware issue. Hard to tell if it ‘s the touchbar itself or some circuit feeding power/data to it. I’m afraid Apple would charge an arm and a leg to fix that. The other alternative would be find some independent lab into component level repairs but that’s not going to be very cheap either. It’s a bit alarming such a thing may happen on a less than 2 years old machine.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Bara Limbong estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 24
Todo El Tiempo: 1,018
