Saltar al contenido principal
El mando (controlador) Xbox One se presentó en 2016 con el lanzamiento de Xbox One S y agrega compatibilidad con Bluetooth para Windows 10. Este controlador corrige muchas de los fallos de diseño encontrados en los controladores Modelo 1537/1697 y es mucho más confiable. Este controlador ha sido reemplazado por el controlador Modelo 1914.
Drift on right joystick without visible fix
I’ve been trying to fix the drift on my Xbox One controller for a while, but nothing has seemed to work so far. Currently, the right joystick is consistently registering a left input while at center. This is a FULL left input, though, as I’ve gone into a game with this malfunction and it would make the camera in the game rotate left at full speed.
I have taken apart the controller already, and tried to replace the circular sensors that are held within the green portions of the joystick module on the motherboard. I’ve even turned on the controller with the sensors completely removed, and there is still a left input on the joystick.
I have a replacement module, but I’m unable to get the current one off since my soldering iron doesn’t seem to be hot enough to melt the contacts. Is it a lost cause? Should I just get a new controller?
UPDATE: I was able to replace the joystick module, but nothing had changed. There is still a full leftward input on the right joystick. The new module is working, as I’m able to see inputs from the joystick as I move it around, but only up, down, and press. So I’m guessing it has less to do with the actual module and something a bit deeper.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
You need another tool to remove the joysticks off a controller. As long as the solder when melting turns shiny / malleable then that means the soldering iron is hot enough but needs help with another tool mentioned below:
This is the tool you need it is called a “Solder Sucker”. Basically what this does is sucks the melted solder into the tool so that it helps you with having the pins under the object that you are de-soldering not to be soldered together with the pad on the board.
Here is a link to the aforementioned tool: https://www.amazon.com/Solder-Sucker-Des...
Filling the pins and pads with leaded solder will make this process easier. Simply add leaded solder to these pads, heat them up for about 5-10 seconds then use the solder sucker with the nozzle propped against the pad and press the button on the tool to have it suck up the melted solder.
You’ll need to do this a few times so that it gets rid most of it properly on all the joystick pads. Once that’s done you may need to use solder wick to remove excess / residue solder on the pads so that you can mount the replacement joystick in place and solder that one into it’s respective pads on the board.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Ah, thank you. I'll check this out.
- de
Saw your update on your post. At this point this problem will need to be diagnosed at board-level.
The cause of the problem in this case would usually be one of the following either liquid damage or physical damage from dropping the controller on the board.
For what it's worth in terms of cost and time it may be time for another controller.
- de
Añadir tu respuesta
Bryan Christian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 21
Todo El Tiempo: 1,723
