Saltar al contenido principal
Pantalla de 27" con resolución de 2560 x 1440 píxeles Conexiones de cable Thunderbolt y MagSafe
Preguntas 20 Ver todo
27" Thunderbolt display turned off after a few minutes(Please help!)
Right, I am using the quite old display manufactured from 2011.
If you want to say buying a dell monitor, please ignore this request.
This symptom happened a while ago and I really tried to figure out why, but I couldn’t find out. Btw, thanks a lot someone who created this forum! I got a lot of knowledge.
So, the problem happens just after few minutes later. When I unplugged it and connected it again, it sometimes fixed. However, it never continue more than 30 minutes. I already tried to connect display from another thunderbolt from back panel instead of all-in-one cable. It works but never continued neither. I replaced the All-in-one cable and there was no change. I replaced the power supply unit with my another apple cinema display(not Thunderbolt display), but it didn’t work. I found out the PSU is the same with the Cinema display.
The things that I can try from now is
1. replacing logic board
2. AC Power Inlet.
Can anyone succeed to fix 27” Apple Thunderbolt Display ever?
I reached out to local repair shop, but they asked me around $400 for fix.
Please help me!! I don’t have money for buying $5-6000 monitor!!!!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios
When the screen turns off on its own take a flashlight and place it on the display at a sharp angle do you see a faint image of the desktop and your icons?
- de
I cannot see any faint image or icons of the desktop. It seems like completely blacked out. As I explained, it works as normal after I re-plugged while minutes after. I have no idea what the problem is.........
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
This is almost always a capacitor issue on the power supply board or controller board - doesn’t matter which monitor you have. It can be repaired, but you probably need to replace all of the capacitors in the monitor.
The LED monitors have fewer failure points then the CCFL monitors they have since replaced, so it’s generally a capacitor issue on these if you have ruled every other practical possibility out as not being the issue. You will need to do a teardown of the monitor to fix this issue.
Refer to this guide to remove the power supply and controller boards for recapping. Practice on a junk board first if you have never soldered before, since a mistake with a soldering iron can (and usually does) mean the end of the damaged board.
Update 6/12/19
Here is the controller board:
The capacitors on the controller board are going to be SMD as there are no through hole points that indicate that they’re through hole. You will need to use a hot air gun to get these off, as a soldering iron tends to not work very well. I do not have the values, but you can get them off of the capacitors or a reference board.
Fue útil esta respuesta?
Puntuación 3
7 comentarios:
Thanks for your comment! I had replaced the power supply unit with my another Apple cinema one, but it didn't work. So, my question for you is what is Controller board? I know how to disassemble and re-assemble with new parts, but I don't know how to solder iron. And what is Capacitor in controller board? Perhaps PSU itselt is not the issue neither I think because the Apple cinema one didn't work. Again, thanks for your kind explanation! Look forward to hearing more from you!
- de
I'll add more information later, but I've added a photo to ID the controller board. For now, the thing to remember is both boards have capacitors and that may be the fault.
- de
Aha! That makes sense. So what are capacitors? Where should I solder? I am afraid to do it, but I just want to know. :)
- de
I added more to the answer.
- de
I saw your red mark, yet it is hard to understand what are capacitors. Do I need to solder entire irons there? Or do you think that buying and replacing the logic board will fix this issue? Thank you for your quick reply, Nick!
- de
Mostrar 2 comentarios más
Añadir tu respuesta
Sean estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 2,262
