Saltar al contenido principal
Procesador Intel Core i5 de doble núcleo a 2,5 GHz (Turbo Boost de hasta 3,1 GHz) con 3 MB de caché L3 compartida.
Preguntas 265 Ver todo
Device is operating upward of 70c while under 5% load
Running Manjaro KDE, cold boot and after 10 minutes idle, the device is operating upward of 70c, while CPU usage is under 5%. SSD is an aftermarket OWC if that matters. Already repasted with Arctic MX2.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
How full is the SDD? Give us the size and how much is free.
- de
480GB OWC Drive, Just did a clean install of Manjaro today. Drive is currently at 12GB used.
- de
Agregar un comentario
1 Respuesta
Make sure you got a good contact with the heat pipes after you reapplied the thermal paste. If that is not the issue than, the only other thing i can think of is the cpu fan isn’t working properly or it is a software issue. I don’t have a whole lot of experience with Manjaro so I wouldn’t be able to help you there.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Samuel J estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 5
Todo El Tiempo: 59
