Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información sobre el dispositivo y la reparación del sistema de altavoces Behringer Eurolive B212D.
When I turn on, Europort PPA500 has flickering lights and won't play
I just got this Behringer Europort PPA500BT system 5 months ago. Turned it on this morning and it won’t do anything. Just flickering lights and will not connect to any bluetooth or anything. Thoughts?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
I got the same problem the unit is $@$*.
- de
Hi, Any of you has found a solution to fix this issue ?
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi @justin42 ,
It seems as though it is a fairly recent model, is this correct?
If it is new, check the manufacturer's warranty before opening the device, to prevent voiding the warranty.
If it is still within the manufacturer's warranty period follow the directions in the warranty on how to obtain warranty service.
Fue útil esta respuesta?
Puntuación 2
@justin42
this “Just flickering lights and will not connect” would guide me toward the power board. time to tear it apart and have a look at the boards. Post some images of hose so we can see what you see. Agregar imágenes a una pregunta existente
Puntuación 1
Añadir tu respuesta
simz_u2 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 1,207
