Saltar al contenido principal
The LG K20 Plus Android smartphone was released by LG Electronics in March 2017 as part of the K Series. The LG K20 Plus includes model numbers LG K20 V, LG VS501, and LG TP260.
Preguntas 20 Ver todo
Why is my phone keeping ringing a weird drum beat sound?
My phone has been acting up lately with this unknown weird sound lately. It sounds like a jazz type of beat and it just won't stop, no matter what I do with it. I restarted my phone, I had to delete other apps that was affected by the sound, and tried everything to make this stop, but it didn't.
Es esta una buena pregunta?
Puntuación 0
1 comentario
just turn off notifications… this will stop the noise…then you can turn on each app notification that you want …wait to see if its the issue…and continue one at a time…no need to delete them
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Hi @markerz2020 ,
Try starting the phone in safe mode to check if it works OK or not.
If it works OK then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit.
You need to uninstall each downloaded app, one by one, and test the phone between each uninstall. When it works OK the last downloaded app that you uninstalled was the cause of the problem
Fue útil esta respuesta?
Puntuación 3
Try resetting you phone.
Puntuación 0
Añadir tu respuesta
Marcos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,462
