Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guía de reparación e información para los controles Joy-Con de Nintendo Switch
Replaced shell, battery no longer works.
I replaced the shell of my right joy con and now it won’t turn off when not attached to the switch, no LEDs, nothing. I’ve checked the battery connecter and there’s no problem. Does anyone know where the problem could be?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I think you messed up your thingy that connects to the switch + has the lights. Is the ribbon in good?
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
Having this same issue. I’m guessing Tom’s answer is probably the cause, but I’d like to know how you proceeded before trying anything for myself if you’re still around.
- de
Hey, I have the same problem. The ribbon was broken after I touched it with my finger. From the start, it was already kinked. Now the joy con has no function.
- de
I'm having this same issue. The battery isn't the issue on mine. I pulled it out and popped it into a different joy-con and it worked just fine. Were you able to test yours somehow or did you figure out what went wrong with your rail?
- de
Some connection is probably not connected, watch the battery replacement and double check all your connections. Reemplazo de batería de Joy-Con
Puntuación 0
Añadir tu respuesta
unnamed estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 2,938
