Saltar al contenido principal
Designed by ASUS in 2015 as a budget laptop made for travel and everyday uses.
Preguntas 2 Ver todo
Charging port LED flashing green, won’t power on
I replaced my chromebooks LCD screen and now when I try to power on the chromebook the LED beside the charging port slowly flashes green (green for about 2 secs, off, green for 2 secs, off, etc).
Does anyone know what this means? I’m not sure if it signifies something I haven’t connected correctly when replacing the screen.
TIA
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
I had the same problem, mine won’t turn in and the battery light is flashing green. I took the battery out and plugged it in to the adapter. It is now flashing green then red, and the power button flashes white but it still won’t turn on. Does that mean my adapter isn’t working properly? I don’t understand why, it’s only a few months old.
- de
Agregar un comentario
1 Respuesta
The flashing green LED usually indicates a charging problem. This could be the power adapter, motherboard, or battery.
Shut down the laptop, take the battery out, and try to start the laptop up with only the power adapter. If it doesn't start, you may have an adapter problem.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Mark Naylor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 42
Ultimos 30 días: 221
Todo El Tiempo: 10,803
