Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La edición más grande del décimo teléfono Galaxy insignia de Samsung, lanzado en febrero de 2019. Se envía con Android 9.0 (Pie).
From whee I can buy the back panel for galaxy s10 plus?
i want to buy the back panel for galaxy s10 plus cuz i broke mine .
and onther q . if i replace it . is the water resistant will go away ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
3 Respuestas
Respuesta Más Útil
As far as I know, there aren’t currently any replacement glass casings on the market. It’s a very new phone! You’ll just have to be patient for suppliers to get some stock, and maybe consider a case…
It most likely won’t be water resistant after a replacement, but if it’s cracked it definitely isn’t water resistant anymore anyways.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
ubreakifix seems like they have parts in stock. Not something you can do yourself but if you need it fixed, definitely an option.
- de
You can replace the back glass yourself, but remember, heat is your best friend! totally not something that jerryrigerverything said ;p
- de
We have guides for the procedure! Follow this guide: Reemplazo de la tapa trasera del Samsung Galaxy S10
- de
Mobile Defenders has the back glass.
It will become less water resistant depending on the type of adhesive and type of way you seal up the back.
Puntuación 0
you can buy a LUVSS back glass from amazon with camera lens and full set tools kit.
Puntuación 0
Añadir tu respuesta
molhamstar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 25
Todo El Tiempo: 2,325
