back camra and flash light
in my I phone 5s camra and flash light is not working they need cool down
Es esta una buena pregunta?
Flash light needs the camera to be working to be enabled. If you notice excessive heat either the camera or a component along camera circuits are getting bad. On a DIY basis you can try replacing the camera, but if that doesn’t clear your issue you’d need a microsoldering technician assistance.
Fue útil esta respuesta?
If this is cause by temperature I believe you could have some hardware issue (component) issue.I think you can try another flash but you will need to remove the power button cable completely to change the flashlight.
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 39
