Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado el 22 de septiembre de 2017. Modelo A1864, A1897. Disponible como GSM o CDMA / 64 o 256 GB / oro, plata y gris espacio.
Front camera flex cable issue
While removing the flex cable with heat the cable separated (not broken) from the other part. It had a little bit of glue. Between both sides it has tiny pins that I guess are supposed to be in contact to work. Camera works but proximity sensor not aswell as the speaker. Please let me know if there is no way to put it back together or I'm better of getting a new flex. Thanks in advanced.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
You could potentially solder the two ends together but the risk is that traces were torn when it broke. When considering the cost of the flex, it’s better just to replace it.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Thanks I thought that was the ideal way to go.
- de
If replace not work true tone
Puntuación 0
Añadir tu respuesta
TxShack estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 22
Todo El Tiempo: 1,095
