U2710 getting hot, no shorts
We have a board that the U2710 gets really hot. I ordered replacement chips and swapped this power switch component.
Same situation stands, This chip really gets hot, the top half of the board doesn’t appear to heat up at all. VDD_Main draws 3.6V with a DCPS, PP1V8_SDRAM draws 0.450V. NAND lines draw nothing.
I suspect power is getting to this component but not getting through it possible?
Would really appreciate a second opinion on something a bit tricky like this. Thank you!
Es esta una buena pregunta?
4 comentarios
Try checking the issue with pp1v8_sdram first as it's to low
- de daniel
Weird, after testing with DCPS, short to VDD_Main came back, was again under U2710, replaced with another and short gone, this happened one more time (10 chips arrived from aliexpress - plenty to test). Seems to get a short when DCPS is on. with a battery this draws 0.01mA. Trying to look at the schematics with ZXW to see where the power should be going.
Thank you for the help so far.
- de Elliot
Whenever I have this with a battery, it draws no power really, DCPS causes a constant short in the U2710, I’m thinking it could be something charhing related with a line, or chip, maybe tristar or tigris. Will update this
- de Elliot
Try the bb_pmic
- de daniel
