LG Refrigerator IS error on LMXS30776S
MY LG refrigerator dispenses water into the ice tray, freezes the ice and then tilts the tray but does not complete the process of dumping the ice. Eventually it gives me an Error 15 and when I do a diagnostics test on it shows an Error IS.
I have changed out the ice maker.
I have changed the main board on the fridge
I have changed the board that is located on the top of the left fridge door ( sub PCB board )
I did an ohm test on the connector 11 & 12 of the ice sensor cable and those are showing normal.
When I do the test to check if the refrigerator thinks the ice tray is full it does show FULL, even though there is no ice in it.
Any thoughts or suggestions would be great…
Es esta una buena pregunta?
3 comentarios
We’ve had several long term power outages in northern Calif. our ice maker stopped filling with water shortly after one of the incidents. We also had to pull it out and put it back each time to hook it up to the generator. I think somehow something went caddywaumpus as a result of these activities but the motor mechanism works and so does water dispenser but no water gets to the ice unit. So frustrating.
- de Katie Somple
My ice maker is doing the same thing. I changed the ice maker and the new one is doing the same thing as the old one was. I gave up.
- de Greg
Same model, slightly different problem. E 15 code on the display. I've changed ice maker module and icing fan in the freezer compartment. No luck. If I turn off the fridge then turn it back on, the error will go away for about 2 hours then show up again. And oddly the ice maker still makes ice even with the E 15 code, just slower than normal, about 6 hours for every batch. I'm giving up..
- de Tony Hong
