Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
La actualización de abril de 2014 del MacBook Air de 13" de Apple presenta procesadores i5 e i7 de doble núcleo actualizados, además de un rendimiento ligeramente mayor de la batería.
Preguntas 246 Ver todo
Does not power on, after water spilled
Hi
My macbook air does not turn on after water spilled
But it does turn on when plugged in and he is charging the battery, i can then unplugged the charger and use the computer, but then again the sound card seems to be missing!
but when i shutdown and try again same problem
NB: when i power on with charger plugged in, the charging lights turn off and on again with orange light come again
i tried to clean it motherboard with alcohol with no luck
any ideas?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
2 Respuestas
Solución Elegida
Sounds like you have a damaged I/O board, where you find the first stage of power supply and audio IC. That part surely needs replaced, but luckily it’s not a very expensive part. Check the ribbon cable too to make sure all pins are still clean and shiny..if you see any charred pin replace the cable too. Here’s the guide for parts replacement:
MacBook Air 13" Early 2014 I/O Board Replacement
Fue útil esta respuesta?
Puntuación 1
Hello Try Resetting The PRAM https://support.apple.com/en-us/HT204063
You might also want to buy this if reseting PRAM doesnt get any sound MacBook Air 13" (Mid 2011-2017) Right Speaker
Imagen de MacBook Air 13" (Mid 2011-2017) Right Speaker
Producto
$14.99
Puntuación 0
Comentarios:
The OP mentioned the system can't find the audio card..replacing the speaker won't likely make any difference.
- de
Añadir tu respuesta
Palli estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 33
