Saltar al contenido principal
Lanzado el 4 de noviembre de 2017. Modelo A1865, A1901. Disponible como GSM o CDMA / 64 o 256 GB / Silver o Space Gray. (Se pronuncia igual que "iPhone 10.")
Preguntas 1120 Ver todo
Why does my iPhone X show vertical Lines?
So after a drop my micro and disolay start not working properly
so my question now: can i replace the screen with a new LCD and will it start working normally again?
best regards
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
This is your answer - this is common especially in the iPhone X. Now although there is no signs of physical damage this can be caused by excessive pressure or even a faulty screen so you need to take it to apple.
iPhone screen has lines through it
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
So would a screen replacement fix it?
- de
yes correct. 100% screen replacement. please mark question as answered.
- de
The display and front microphone are part of the same module, so assuming the connectors of the display assembly to the logic board didn’t damage in the drop, a display replacement will fix your issue most likely.
Puntuación 0
Añadir tu respuesta
Nenadbrateu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 5,281
