Saltar al contenido principal
Azpen A701 7 inch touchscreen tablet released in February 2014 with a 1.GHz Cortex A8 processor.
Preguntas 6 Ver todo
azpen a727 charger port broken
i bought the tablet in 2014 thr charger port got loose in 2016 and came out one of the pins broke off the outher one is stull attached i tryed to get it fixed before i was running all over different places in nyc they all said same thing theres no way to fix this so since it been 2 years sinced i tryed to fix it mabey theres a way to fix it now since its 2019 and now there's more technology
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
If the tablet hasn’t been charged for over 2 years it may be more than the charge port that needs replacing.
The battery may have become depleted beyond recovery and will also have to be replaced.
Here’s a link to the ifixit Azpen A727 Back Cover Replacement guide.
It shows how the back cover is removed so that access is possible to remove the systemboard so that the charge port can be replaced.
As the charge port is a SMD (surface mounted device) type component, you’ll need SMD soldering skills and tools to effect the repair. This is not a job for novice repairers.
Replacement USB connectors are available from here but you’ll have to find the exact one as there are differences as to mounting etc. (compare it to the one in your tablet - look at the position of the mounting lugs and the pins)
If the battery has failed you may be able to source a new one online. Find the battery model number (printed on the battery) and use it to search online for replacements.
If this seems to daunting contact a reputable, professional electronics or mobile phone repair service and ask for a quote to repair the tablet. You’ll probably be told that it is not economically viable (for you) to get it repaired professionally
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
the gamer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 249
