Saltar al contenido principal
HP Elitebook 6930p se anunció en septiembre de 2008 y fue una de los portátiles EliteBook de primera generación. Fue anunciado como el primer portátil en romper la barrera de la vida útil de la batería las 24 horas.
Preguntas 16 Ver todo
How do I go about replacing the screen of my device?
My elitebook screen broke few years back and I gave up on the thought of fixing it because previously the battery,speaker,keyboard and touchpad had all gone faulty. I had to add a lot of externals to use it but the screen getting broken was just the last straw.
Recently however, I decided that I'll need to repair this pending when I can get a better one. I want to fix it myself and the screen seems like it may be my biggest challenge yet. Please help. Thanks
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @osazeyyh ,
Here’s a link to the service manual for your laptop.
Scroll to p.85 to view the necessary pre-requisite steps and then the procedure to remove the display assembly.
Also on p.85 you will find the part numbers for the various displays available for the laptop.
If you search online, typing the part number only (appropriate to your particular model variant) in the search box of your browser, you will get results for suppliers of the part. If you wish to verify that you have the correct part number it is usually stamped on the back of the display panel.
Hopefully this is of some help.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thanks so much! I'll go through the service manual and see what I can do.
- de
Añadir tu respuesta
Osaz Eyyh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 118
