Saltar al contenido principal
Serie de portátiles HP Pavilion lanzados en 2015. Se sabe que la serie Pavilion 15-p es difícil de mantener.
Certain Keys On Keyboard Are Unresponsive
My HP Pavilion 15-e013TX’s built-in keyboard has some keys unresponsive (A,S,D,F,J,K & L to be specific) I tried most of the things on https://au.pcmag.com/how-to/9345/how-do-... but the problem still prosper.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Most of these are because the keyboard has failed or the connector is loose. It may work again if you reconnect the keyboard internally, but it’s generally due to a matrix failure.
In your case, you picked the wrong system :-). The 15-e has a modular keyboard, which isn’t the case on the 15-p series. Refer to the Service manual to replace the keyboard and get the part number that matches the country you are in. The US part numbers are 719853-001 or 720597-001.
Fue útil esta respuesta?
Puntuación 2
You will have to change all the Keyboard
Puntuación 0
Añadir tu respuesta
FAMASyCoyote 358 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 266
