Saltar al contenido principal
Modelo A1181: procesador Core 2 Duo de 1.83, 2, 2.1, 2.13, 2.16, 2.2 o 2.4 GHz
Preguntas 1196 Ver todo
Cracked Case?
Near the thumb-scoop there appears to be a small crack running parallel to the case (follows the curve of the scoop) and is about the length of the trackpad button. It is only small but is there something I can do without replacing the entire case?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Solución Elegida
You have to show it to your local Apple Service Provider. I some cases Apple will repair the MacBook.
- shurai
Fue útil esta respuesta?
Puntuación 2
1 comentario:
It's not under warranty though
- de
I see, so the top case actually has a crack in it. For a complete fix you will need to replace this. You can use this guide to carry it out.
Puntuación 2
2 comentarios:
I'd rather not pay $169 USD and just keep it as it is. It doesn't bother me so i will just leave it
- de
I agree, maybe you could try shurai's suggestion?
- de
If the crack is on the keyboard then they'll repair it at no cost. They said it is recognized as a design flaw. However if the crack is anywhere else then you'll have to pay for it
Puntuación 0
I have the same problem with my black macbook, I use black electrical tape to cover it, it's the perfect color, if you have a white macbook you could use white electrical tape.
Puntuación 0
Añadir tu respuesta
AussieMac estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,641
