Why is my digitizer not working?
Just replaced my LCD screen and digitizer assembly. I note the following things. When I turn on the screen it turns on but starts dark and then brightens. I have checked all connections and connectors (pics attached). However the digitizer does not work.
I noted from reviews of this product from this seller that the digitizer not working was a common issue. Did I just get a bad part?
Es esta una buena pregunta?
1 comentario
So replaced the LCD/Digitizer 2x now. Both times visually the screen works fine. However, the digitizer does not work. In both cases the replacement went fine. What's wrong? I've double/triple/quadruple checked the connections, could they still not be right? What else could I try. Did I break the touch IC? not sure what this is and some quick research shows I can't fix it... what is the typical cost of such a repair?
- de Chris Massey
