Saltar al contenido principal
Find repair and additional information for the GE Refrigerator GNE29GMH****, a compact and built-in French door style refrigerator with a bottom-mounted freezer, featuring automatic defrost, an ice maker, and through-the-door service. This page covers information for model numbers matching the pattern GNE29GMH****.
Preguntas 1 Ver todo
Why is my fridge and freezer not cooling?
I have a GE profile model number GNE29GMHDES
Its new to me but it was a home show unit according to the seller. I have vacuumed the rear of the fridge around the condenser. And there is no frost I can see.
The fans seem to be running. But there is no air coming out behind the meat drawer. And it seems as if it's cooling but not enough.
Im thinking it might be the thermostat or that relay?
It's odd since it will cool down if we don't open for hours.it can go from 22 degrees in the freezer to 9 in a day. But it will not go down to 0.
So confused. And I'm waiting on a repair guy. But I want to know if I can fix my problem. I cant afford to have a huge fix….
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Now I want you to hang in here and have a discourse with me as you have at least a couple of problems but I believe we can can get them diagnosed and fixed if you talk to me. Besides my fee is probably the best anywhere
We want to go after the temp in the freezer first. I need you to have an accurate temperature reading both the the freezer and fridge.
As for the frig temperature, it is predicated on the freezer temperature. There is a baffle between the two and I think yours is closed or partially closed. The control is usually located by the lower meat compartment. Slide it open.
Now the most common probabilities:
first are dirty coils but you have that in hand. Next
Condenser Fan Motor
The condenser fan motor draws air though the condenser coils and over the compressor. If the condenser fan motor is not working properly, the refrigerator won’t cool properly. To determine if the fan motor is defective, first check the fan blade for obstructions. Next, try turning the fan motor blade by hand. If the blade does not spin freely, replace the condenser fan motor. If no obstructions are present and the fan blade spins freely, use a multimeter to test the fan motor for continuity. If the condenser fan motor does not have continuity, replace it.
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Start Relay
The start relay works in conjunction with the start winding to start the compressor. If the start relay is defective, the compressor may sometimes fail to run or may not run at all. As a result, the refrigerator will not be cold enough. To determine if the start relay is defective, use a multimeter to test it for continuity between the run and start terminal sockets. If the start relay does not have continuity between the run and start terminal sockets, replace it. In addition, if the start relay has a burnt odor, replace it.
Temperature Control Thermostat
The temperature control thermostat directs voltage to the compressor, evaporator fan motor, and condenser fan motor (if applicable). If the temperature control thermostat is not working properly, it may prevent the refrigerant system from running. To determine if the thermostat is defective, rotate the thermostat from the lowest setting to the highest setting and listen for a click. If the thermostat clicks, it is not likely defective. If the thermostat does not click, use a multimeter to test the thermostat for continuity. If the temperature control thermostat does not have continuity at any setting, replace it.
I have more, but lets check these first.
UPDATE 12/5/18
How to Know When a Refrigerator Needs More Freon
Step 1
Locate the refrigerator's condenser and place your hand next to it to sense heat. If the condenser feels cold and the refrigerator has been running, there may be a lack or absence of Freon. The problem may also be due to a defective condenser or clogged system.
Step 2
Unplug the refrigerator, turn the refrigerator's temperature control off and place your ear against the side of the refrigerator. Hissing and gurgling sounds indicate that Freon is present and equalizing. Silence, however, doesn't necessarily indicate a lack of Freon – there may be a problem with the condenser, fan, filter-dryer, cap tube, defroster or compressor.
Step 3
Remove the cover from the evaporator, located in the freezer near the evaporator fan. Plug the refrigerator back in and turn the temperature control back to your desired settings. Wait for the refrigerator to run for a few minutes with the door closed. Check the evaporator for frost. An absence of frost indicates a lack or absence of Freon or a clogged system.
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
So i unplugged it from about 9am till 315pm. Water in the back. I have plugged it in now. And the fan at the back of the freezer is not running.
What on earth could have caused that to happen?
- de
How long have YOU actually had it? When they brought it on the truck was it lying down or standing up?
- de
We have had it since April. It was transported upright. And left it a couple hours. It was working great. Then last week it started to get warm
The repair person says there is no refrigerant.... Im not sure I buy that
- de
@deslauriersj no refrigerant? - see update to answer
- de
Hi @deslauriersj ,
There is an evaporator fan #410 behind a panel inside the freezer compartment that should be running to cool the fridge down to the required temp. You should be be able to hear the fan stop and start as you open and close a door.
if you can’t hear the fan it is either faulty or may be “iced up'‘ preventing it from turning. If it is iced up there may be a problem with the defrost system, e.g. defrost bi-metal thermostat or the defrost heater
There is also a temperature sensor #511 that should tell the control board whether to keep cooling the fridge or whether to stop the compressor and the evaporator fan as the correct temp has been reached.
The part identifier numbers were taken from this link - freezer section
Puntuación 1
Añadir tu respuesta
Jessica DesLauriers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 2,719
