How to fix iPhone 3G Digitizer? (Touch is not responding)
Hi,
I have iPhone 3G, and the bottom of the screen is not responding for touch (I can't "slide to unlock").
Tried to do a clean restore for different firmwares - but nothing helped.
The Question are:
1. What is responsible for this problem?
2. If it is the Digitizer, so can you add a digitizer image/photo so I will see what is it?
Googling Digitizer gives images of LCD screen.
3. Fixing the digitizer - If I want to open the iPhone, What are the risks on the way to the digitizer?
Can I damage anything "on the way"? Is there any chance that after Reassemble the device I will have more problems?
4. It's the first time I open this iPhone - I will need probably Glue for the frame, for the Antena, GPS, Wifi - Right?
5. Do you have more suggestions for things I need before I start?
thanks
Shai
Es esta una buena pregunta?
2 comentarios
Hi,
thanks I already followed.
The thing is that I have some "open issues" - things which are not fully clear for me, and it blocks me from restart the repair :/
Thanks again,
Shai
- de Shai
shai, all you are doing is lifting the glass and lcd, not the metal frame at all.. you don't need to worry about antenna/gps/wifi. because you are not taking out the frame you don't need glue.. in the guide you will see that the digitiser sits in a black plastic frame and it is here that you use the double sided tape to stick the digitiser to the frame.. no glue. the digitiser is on the back of a glass panel (it comes as a unit) the lcd is separate, and screwed in to the black plastic frame to form the back of the display unit. think of it as taking the lid off a container, that's all you are doing. the only "tricks" are the 3 connectors you need to open to remove the display that I've already mentioned.
- de pollytintop
