Saltar al contenido principal
Guías de reparación y soporte para planchas de pelo, también conocidas como alisadoras.
Preguntas 34 Ver todo
How can I fix a short in the wire?
I have a Linea pro flat iron with the pants clip. There's a short in the wire and I have no idea where to get it fixed.
Update (04/01/2019)
How could I fix one myself. No wires are exposed. I could take a picture
Es esta una buena pregunta?
Puntuación 0
1 comentario
I believe it is where the wire connects. It can swivel and I think it's there. It's a old Linea pro leopard print.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
See if either one of these guides will give you a clue as to how to open it up to check it for burned components. Use a multimeter to test it for continuity to find the problem.
CHI Original Circuit Board Replacement
Hot Tools HPK12 Cord Replacement
Imagen de Hot Tools HPK12 Cord
Guía
Dificultad:
Fácil
10 minutes
Imagen de CHI Original Circuit Board
Guía
Dificultad:
Difícil
1 - 2 hours
Fue útil esta respuesta?
Puntuación 3
hello Sora, if you fix it your self it would be cheaper on you. For a shop to fix you would want to compare cost of product to repair cost. Most likely the short would be at the point of where the wire comes into the main unit being pulled out or to short in wire length overall.
Puntuación 1
Añadir tu respuesta
Sora Kururugi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 596
