Saltar al contenido principal
CHI Original Circuit Board Replacement
Qué necesitas
  1. CHI Original Circuit Board Replacement, Hinge Spring: paso 1, imagen 1 de 2 CHI Original Circuit Board Replacement, Hinge Spring: paso 1, imagen 2 de 2
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Circuit Board Replacement: paso 2, imagen 1 de 1
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Circuit Board Replacement: paso 3, imagen 1 de 1
    • Remove the hinge pin.
  4. CHI Original Circuit Board Replacement: paso 4, imagen 1 de 1
    • Separate the two halves of the CHI Original.
  5. CHI Original Circuit Board Replacement: paso 5, imagen 1 de 2 CHI Original Circuit Board Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Circuit Board Replacement, Power Cord: paso 6, imagen 1 de 2 CHI Original Circuit Board Replacement, Power Cord: paso 6, imagen 2 de 2
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Circuit Board Replacement: paso 7, imagen 1 de 1
    • Gently pull upwards on the connection point and disconnect the power cord.
  8. CHI Original Circuit Board Replacement, Circuit Board: paso 8, imagen 1 de 3 CHI Original Circuit Board Replacement, Circuit Board: paso 8, imagen 2 de 3 CHI Original Circuit Board Replacement, Circuit Board: paso 8, imagen 3 de 3
    • Remove the (2) .27" Phillips head screws on each half of the CHI Original.
  9. CHI Original Circuit Board Replacement: paso 9, imagen 1 de 3 CHI Original Circuit Board Replacement: paso 9, imagen 2 de 3 CHI Original Circuit Board Replacement: paso 9, imagen 3 de 3
    • Remove the covers on both halves.
  10. CHI Original Circuit Board Replacement: paso 10, imagen 1 de 1
    • Remove (2) .15" Phillips screws from the circuit board.
  11. CHI Original Circuit Board Replacement: paso 11, imagen 1 de 2 CHI Original Circuit Board Replacement: paso 11, imagen 2 de 2
    • Desolder all points of contact between the circuit board and wires on the ceramic heating elements.
Conclusión
Una persona más ha completado esta guía.
Eric Knigga
Miembro Desde 08/23/17
215 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G2, Freund Fall 2017 Miembro de IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 40
Todo El Tiempo: 3,013
