Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lavadora de carga superior de 3.5 pies cúbicos con agitador de doble acción. Lanzada en 2016.
Amana NTW4516FW Washer does not advance to rinse cycle
The washer fills, agitates, and spins. Then it thinks it is done and shuts off. The washer needs to be set to a manual rinse cycle after washing. It also seems to have issues with auto sense. Water level seems deeper than necessary, so that washing small loads is not water efficient.
Es esta una buena pregunta?
Puntuación 10
20 comentarios
I have a Amanda washing machine that is stuck on wash and doesn’t go anywhere else I have reset the motor 2time all ready does anyone out there know why or what I can do it not that old got it last year
- de
I just had the same problem too check the cold water intake screen take your hoses off the back of the washer and check them screens if them are clogged the machine will not function properly
- de
I just read about the washer fills and stalls at the wash cycle and they have to stand by it and do it manually
- de
I am really tired of spending hours trying to get my New Amanda was her to go through the entire cycle. It stops after the wash cycle, and then I have to try to get it to rinse and spin, but it just goes back to the wash light ! What can be done to fix this problem?
- de
Hi @Bette Moore
If it is new i.e. <12 months old, follow the manufacturer's warranty directions to get it repaired under warranty.
- de
Mostrar 15 comentarios más
Agregar un comentario
8 Respuestas
Solución Elegida
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Fue útil esta respuesta?
Puntuación 3
16 comentarios:
I replaced the control unit with a brand new one and still the same thing.
- de
also the lid switch seems to work just fine
- de
Please re-read my answer, it mentions the Timer five times.
- de
How do you reset a timer
- de
Connie, you can reset the whole machine by unplugging it for 5 minutes
. That failing, it's time to replace
- de
Mostrar 11 comentarios más
Respuesta Más Útil
This machine has no timer. It is controlled by a main control board. Check water intake of cold water
entering machine. Make sure it is a steady flow. If that checks good. More than likely it is the shift actuator.
Part # W10913953 . This part senses load size. RPM’s & shifts the cam assy from agitation mode to spin mode.
To reset your washer. Make sure all LED lights are off. You will need to turn timer control knob one click @ a
time as instructed below. slow & steady clicks.
L > R > R > R > L > R
all lights will LED’s will flash. Turn timer control knob until just the rinse light is lit. Press start. The machine will
go through a 3 to 5 minute calibration mode resetting the machine.
Puntuación 11
10 comentarios:
Thanks very much Mike. Do you know if the water saver feature can be turned off or decreased? We live in the country and have lots of water. This machine is trying to wash the clothes dry!!!Almost.
- de
Do you know where I can get a list of the control codes for the Amana Top Load (NTW4516FW3)? I pulled the codes based on your response and a YouTube video. I think the codes are F4-E0, but cannot find anywhere that tells me what that means.
- de
Perfect information. Helped me fix my problem in 8 minutes after I had decided it must be the "control board." Thank you!
- de
Fyi, I did not have an @a so I tried one full revolution to the left and stopped on normal then continued the instructions. Worked perfect.
- de
My washer sat in "wash" mode, and wouldn't advance to rinse. I held the "pause/unlock button, and it sounded like it was emptying the wash water. Finally, no LED lamping. Performed the instructions (left, right, etc). Thank you. Working again
- de
Mostrar 5 comentarios más
@jphonedude,
Here’s the tech sheet for your washer.
The fault code you mentioned is not shown so maybe it is a control board issue.
Check what codes it shows when running the diagnostics as per the tech sheet.
Puntuación 3
3 comentarios:
WOW! That was exactly what I've been looking for! Other sources had me interpreting the codes incorrectly. According to your sheet, my error is F8E1. this makes perfect sense for my situation and has pointed me in the right direction for troubleshooting.
Thank you very much!
- de
I'm losing it! My older Amana top loader washer will not advance after filling up at start of cycle. The lid lock is not bent/broken obstructed, seems the usual/fine but all of a sudden since last night it's not registering as "locked" in terms of the red light, thus preventing it from moving on to next step I imagine? Anyhoo, after many hours of helpful youtube, I have done the rotating L R etc, and it works, it will go all the way to rinse flashing/I hit start and everything starts running- but only for a few seconds (not the 2/4 mins all online posts suggest) and stops before displaying any error codes. All the green lights do their thing etc. for 6 seconds, then halts /red lid lock flashes a couple times washer stops dead. Too broke for professional help and don't know/trust anyone to help? Not doing anything wrong just can't make it past this point. Thanks for reading this nervous rant! Any help appreciated!
-Grateful, broke, single young lady.. with tools and hope! Lol
- de
My Amanda top loader would fill and lock lid but would not advance to rinse a spin cycle and lid stayed locked. Unplugged and could get lid unlocked?
I thought the control board may be bad.
But GREAT NEWS , I moved the washer
an noticed the drive belt under the washer
Had came off. Vibration had caused the screw that held the belt guard in place to come off . PUT-BELT and Belt GUARD back on! WORKS GREAT !
Hope this helps some one
- de
If your newer washer is stuck on wash and won’t advance to the next cycles. Take the cold water hose off the machine side and clean it. The screen won’t come out, so you need to take a tooth pick or something like one and clean it by sticking it around the slots on the out side edge of screen. Little small black peace’s of black dirt will stop your washer from working. My washer is only a year old. It’s works!!!
Puntuación 2
1 comentario:
Yes, our neighborhood is on well water and there was clay buildup on the cold water intake. However, the little screen does come out.
Look for a tiny "nipple" in the middle and gently pull it straight out. with it in-hand it is easier to clean under a faucet and then slip it back in place before re-attaching your cold water hose. Thanks for the response!
- de
Hi @ lucky freeman
Here’s the tech sheet for your model washer.
Run the diagnostics as described in the sheet and check for any error codes.
If there are any, use the sheet to check what the code means and the most likely cause.
It may be better this way than to assume that the fault with your machine is related to the same faulty part as others in this thread. Just because the symptoms are the same doesn’t necessarily mean that the cause of the problem is the same.
Puntuación 1
1 comentario:
- de
I can't thank you enough for sharing these troubleshooting tips!
Dealing with a washer that's stuck in the wash can be incredibly frustrating, and I've been there myself.
Your step-by-step guide is a lifesaver, especially for someone like me who isn't exactly a DIY expert.
I followed your advice and started by checking the power source and ensuring the door was properly closed.
It turned out that a loose power connection was the culprit, and a simple fix got my Amana washer back on track.
I was amazed at how something so minor could cause such a major problem.
Your suggestion about resetting the washer by unplugging it for a few minutes also did the trick when the problem persisted.
It's the little things like this that can save us from costly repairs or replacements.
I appreciate your clear explanations and the emphasis on safety throughout the process.
It's evident that you care about your readers' well-being and want us to tackle these issues safely and effectively.
Your blog has become my go-to resource for appliance-related issues,
and I'll be sure to share it with friends and family who might face similar problems with their appliances. Keep up the fantastic work!
Puntuación 0
I lost my job today unexpectedly and am trying to be strong- but can someone help me? Please? I pride myself as a single 30 yo with a humble lil home on my ability to be handy and teach myself through these things, as the internet is an amazing place, but I'm losing it! My older Amana top loader washer will not advance after filling up at start of cycle. The lid lock is not bent/broken obstructed, seems the usual/fine but all of a sudden since last night it's not registering as "locked" in terms of the red light, thus preventing it from moving on to next step I imagine? Anyhoo, after many hours of helpful youtube, I have done the rotating L R etc, and it works, it will go all the way to rinse flashing/I hit start and everything starts running- but only for a few seconds (not the 2/4 mins all online posts suggest) and stops before displaying any error codes. All the green lights do their thing etc. for 6 seconds, then halts /red lid lock flashes a couple times washer stops dead. Too broke for professional help and don't know/trust anyone to help? Not doing anything wrong just can't make it past this point. Thanks for reading this nervous rant! Any help appreciated!
Puntuación 0
1 comentario:
Hi @ritazito,
Please confirm the model number of the washer?
- de
Mine did the same, even after calibration. So now, after I push start, I wait for the "click". Then open the lid and shut it. Press start again. This allows it to complete the cycles
Puntuación 0
1 comentario:
Thanks Vicki!!! When I try that it unfortunately still wont move passed filling up. Darn
- de
Añadir tu respuesta
Shelly C in Tucson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 61
Ultimos 30 días: 390
Todo El Tiempo: 77,553
