Regulator/ rectifier location on 1980 GS1000
Please tell me where my rectifier is located on my 1980 GS 1000. I cant find any website that tells ! Thx!
Es esta una buena pregunta?
Hi @bozmandan ,
Here’s a link to the relevant page in the service manual that describes how to test the regulator. The following two pages elaborate on how to test the rectifier.
They’re probably combined in the same housing.
Admittedly it doesn’t state where the regulator/rectifier unit is actually located but it must be very close to or a part of the alternator. There should be 5 wires attached to the rectifier, Yellow, White/Red and White/ Blue from the alternator, Red from the battery and Black/White from earth and also a Green/White coming from the alternator as well which goes into the regulator section. so it should be easy to spot.
Hopefully this is of some help
Fue útil esta respuesta?
The rectifier/regulator is located under the rear of the engine just in front of the back wheel. It faces the ground. It’s the thing with the cooling ridges on.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 565
2 comentarios
Need far more information than you have given!…However a rectifier as it’s name implies changes something?.
If this is a electronic device GS1000 you might be thinking of a component that changes AC to DC.?
- de Thomas
If this GS2000 is driven by a PSU then a rectifier will be found after the input of AC
- de Thomas
