iPhone 6s Plus weak WiFi signal after being dropped
Should I replace the WiFi IC? Or the antenna?
I heard changing of WiFi IC would disable WiFi function? it that real?
Es esta una buena pregunta?
Wi-Fi IC (Also known as Wi-Fi chipset) requires micro-soldering to replace the chip and the NAND would also need to be reprogrammed to have the matching MAC address to the Wi-Fi IC.
Weak signal is more likely caused by damaged iPhone housing / antenna cables or connectors.
Fue útil esta respuesta?
Hmmm...this is strange...the question that is.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 177
