Stripped screws on battery cover
Would this item IF145-118-1 be able to remove the srews for the battery cover on this device
Es esta una buena pregunta?
Sure, there is a possibility those would work. If those fail to remove your stripped screws, you can use the guide below for more tricks on extracting stripped screws.
Fue útil esta respuesta?
yes it should. It is your best bet next to a Dremel
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 370
