My brake light on dash stays on
Parking brake switch, brake light on dash stays on
Es esta una buena pregunta?
Hi @pissingmeoff ,
The “brake” indicator light in the dash has two functions.
It indicates that the parking brake is applied and it is also a low brake fluid level warning light.
If the light is on with the ignition on but the parking brake is released then first check the brake fluid reservoir to ensure that the brake fluid level is correct.
If it is OK then perhaps there may be a faulty sensor in the reservoir or the parking brake switch may be faulty
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 38
Todo El Tiempo: 3,489
2 comentarios
You could bring it to the nearest Mechanic shop and get it fixed there.
- de First Name Last Name
Had all that fixed and it’s still on
- de James
