Saltar al contenido principal
Introducido el 5 de enero de 1995, el Sentra cambió de una suspensión trasera independiente a una configuración de barra de torsión. Algunas variantes no estaban equipadas con una barra estabilizadora trasera o frenos de disco traseros
Preguntas 6 Ver todo
Will changing the auto transmission fluid help?
My 1999 Sentra GXE with 150000 good miles is starting to have shifting issues. Stubborn up shift from second to high and a “hard” shift from low to second. The transmission fluid has never been changed. If it is done now, do you think it will help prolong the transmission, maybe solve the problem?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
As it has never been changed, it certainly won’t hurt the transmission by changing the fluid with the correct replacement fluid, (see 2nd image for details). If there are any metal flecks floating in it they will only cause more damage as time goes by not less.
According to the maintenance schedule from the owners manual for your vehicle the automatic transmission fluid should be inspected every 15,000 miles and changed every 30,000 miles (or 2 years) if towing a trailer, using a camper, using a car top carrier or driving on rough or muddy roads.
Here’s an image taken from the owners guide that details this
(click on image to enlarge for better viewing)
Here’s an image showing how to check the ATF in your vehicle.
Here’s a video that may help you decide whether to change the fluid or not.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Dave Yates estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 794
