Print is always too high on page
If I send a job to the printer it always prints too high on the page loosing the top 4mm approx
Es esta una buena pregunta?
Hi @michaelnm ,
Not quite sure re your printer as it isn’t mentioned in the user guide but check either the printer’s control panel under setup > tools or similar or perhaps in the printer properties menu in the computer whether there is an option to “align the printer” at all.
Most printers have an print alignment test option.
If it has this option see if it resolves the problem for you.
Fue útil esta respuesta?
Thank you - I should try the easy options before taking the printer to pieces!
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 2,196
