Saltar al contenido principal
Una cámara digital simple de apuntar y disparar con LCD de Canon.
Preguntas 14 Ver todo
battery leaked, fixed not working properly
I left batteries in my A570.  They corroded.  I have cleaned the cavity and contacts and installed new batteries.  the camera opens but I cannot take pictures.  it seems to default to a screen to enter date/time etc.  none of which I can get to work either.  any suggestions?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @wheeling ,
The battery acid may have leaked through the battery compartment and affected components nearby.
You’ll have to disassemble the camera and see if this may be the problem.
As I was unable to find a teardown guide or video online for a Canon PowerShot A570, here’s a link to the ifixit Canon PowerShot A540 guide. Hopefully it is a close enough model to be of some help.
If you do find evidence of corrosion etc, try gently cleaning it off using a Q-Tip and Isopropyl Alcohol 90%+ (available at most electronics supply stores). If you can avoid it do not use rubbing alcohol, as this is usually only 70%IPA or less, can contain scents and is therefore not as effective in clearing away corrosion.
If you find this too daunting, contact a reputable, professional camera repair service and ask for a quote to repair the camera
Fue útil esta respuesta?
Puntuación 4
2 comentarios:
Thank you.
can you recommend a source for a refurbished unit.  I would donate or trade mine for that.  I can send pictures of the camera.
thank you.
- de
Hi @wheeling ,
Places such as Ebay etc are usually a good source of used and refurbished devices. Obviously use your own judgement regarding buying from a particular seller etc. if you decide to take this option.
I don't know about donating it but if you decide to get another A570 you could try dismantling yours and check if you can see the problem.
You could always then Atrévete a reparar: cómo crear una guía for the teardown procedure which may help others who may have suffered the same predicament. ;-)
- de
Añadir tu respuesta
Richard McCray estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 555
