Saltar al contenido principal
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
Preguntas 131 Ver todo
Samsung galaxy tab 4 Tablet reboots every 15 minutes?
After not using my tablet for about 6 weeks I struggled to get it to charge. After buying an original samsung charger its all sorted but not the tablet reboots every 15 minutes.
Following other suggestions I cleared the cache in asr mode, and have also done a full wipe in asr mode. Now it loads up connects to the wifi and then reboots every 15 minutes or so.
Any ideas? TIA ☺
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
13 comentarios:
I am assuming that what you mean by a “full wipe in asr mode” is that you have tried to do a factory/hard reset?
https://www.technipages.com/galaxy-tab-4...
- de
Hi, Yes. Full factory reset by turning tablet off. Holding power, volume up and main button down until android symbol appears and then rebooting.
- de
Sounds like a chip fault, changing the battery might help but it sounds like it’s on it’s way out.
- de
Hi,
Does it do this with the charger connected and switched on?
- de
Not tried that but will do that now and get back. Thanks!
- de
Mostrar 8 comentarios más
Agregar un comentario
1 Respuesta
Since i had many tabs that response badly when battery needs to be replaced i would try that first. Otherwise iT can be a heating problem. But my guess is changing the battery Will work.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Nichola estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 135
