Saltar al contenido principal
El Logitech M170 es un ratón inalámbrico de Logitech. Lanzado en 2016. Número de modelo: M170.
Preguntas 8 Ver todo
Dropped mouse now red laser light not working
Logitech Wireless w/ Keyboard (receiver and keyboard work fine) mouse dropped now redlight does not turn on. M-R0013 new battery - tested in remote works fine -
Es esta una buena pregunta?
Puntuación 8
1 comentario
@ repair pug, I did attempt to see if fixable, however there were multiple pieces of plastic, metal and loose circuit boards. Just bought a new one. Thank you for taking time to answer!
- de
Agregar un comentario
8 Respuestas
Solución Elegida
I did take apart, several pieces broken. Just replaced it. Thanks
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
Sounds like the Optical light came off the PCB (Printed Chip on Board) from my research this is an ongoing issue with the mouse after being dropped.
-My best bet would be that the light came off the solder joints with - or + connections and causing it not to light and unable to reflect a light to the sensor.
You could try taking the mouse apart by locating all the screws, some may be under the mouse glider pads on bottom of mouse, and pop it open with a spudger prying tool.
Make sure both the LED connectors are seated correctly into the solder joints on
- and + on the PCB.
Puntuación 4
1 comentario:
layman terms
- de
Mice are not durable. But you could have dialoged one of the boards. You could disassemble and see.
Puntuación 2
This just happened to my daughter’s mouse yesterday. I simply took the mouse apart (just one screw) - and snapped it back together - it works fine now. (I think the drop must have moved the roller off of its proper position). It took longer to find the right screw driver than to fix the problen (probably 2 minutes total once I had the screw driver)
Puntuación 2
1 comentario:
Thank for the advise I fixed mine after reading this , the pointer sensor was hooked off I just snapped it back into position
- de
My mouse was dropped, the red light no longer works, but the mouse still does with no issues? WTF is up with that?
Puntuación 2
i had purchased Logitech M221 silent mouse and realize that the Optic light is not working, but the mouse is working perfectly alright. Hence requested for a replacement and surprised to receive a new mouse again in the same condition. So wondering whether the Optical light will work or not on this model.
Puntuación 1
1 comentario:
Yes I ordered the same M221 same problem r- they replaced it - same issure - just bought the M185 with Keyboard and Mouse wireless - WONDERFUL!
- de
Have the same trouble with Mac mouse. Seems odd the that the diode tracker light not working but mouse seem(?)
to be totally functional-wassup?
Puntuación 0
Wow! 3 Yrs later dropped mouse again - TBH I have dropped many many times but this time in pieces like 3yrs ago when it wouldn’t work. Followed directions from above:
@repair_pug
it worked- thank you!! [It - meaning light didn’t work - dislodged from hit to ground- I used plastic tools that I bought for fixing phone screen-so not to short anything out- I easily pushed a wire and plastic back to where it looked like it should go. ]
works great -with a lil tape also ? Thanks
Puntuación 0
Añadir tu respuesta
anggnbama estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 144
Todo El Tiempo: 55,315
