No signal after charge port replacement
Did a charge port replacement on a note 5. After, the phone will only search for signal. Is that because I did not use the right charge port that is compatible with that carrier?
Es esta una buena pregunta?
Yeah that is probably the case.
The charging port variants have the antenna connector prongs in different locations which is why I do charger port replacements via soldering and not the whole charging daughter board.
Edit forgot to add this: You have confirmed that the two antenna cables are plugged into the charging board and logic board right?
Fue útil esta respuesta?
Yes, I did. All the antenna cables are plugged in. The model number on the original is SM_N920T_SUB. The charge port that I ordered had different different model on it. I am assuming that the “T” stands for T-Mobile? That is the carrier of my phone. I googled one with the letter being “A” an it popped up AT&T.
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 2,278
