Vertical Lines on my Samsung LN46c630 LCD tv
Couple of days ago, out of no where vertical lines appeared on my Samsung LN46C630K1FXZA 46 inch LCD TV. I did some research and it seems i may need to change the Tcon Board. I went on youtube and it seems that youtuber said by changing or replacing the ic chip, will fix most of the lines issues on a samsung board.
I went onto shopjimmy.com. On their website, it states that changing the Tcon Board will not fix horizontal lines.
So, since my is a vertical line issue, i'm hoping it will solve my problem. But i also read on here, someone else changed their Tcon board and it didn't do anything to fix their issue. I'm hoping i don't have to change out other boards that are on the back of the LCD tv.
Here are some pics of the vertical lines. Thank you.
Es esta una buena pregunta?
3 comentarios
Either this forum is dead or folks doesn't know the answer to my question
- de Chris Reynold
I changed out the main board. It didn't fix the problem. It seems it could be the LCD screen.
I looked around for a price and for $900, I'm better off buying a new TV.
Unless there could be cheaper options. After changing out the Tcon and the main board, I don't know what else I could change out that won't cost me an arm and a leg.
Cable connection seems to be good. I checked the connection and there wasn't and loose fitting cables.
Plus I would have to assume if the LVDS cable was bad, I wouldn't get any picture.
- de Chris Reynold
It seems it's the screen that has gone bad. And price to replace the screen or the 1 I found, they were asking for almost $900.
Seriously, why even bother for paying for that much.
I guess they are hoping a dummy will buy a screen
- de Chris Reynold
