Why is my power wire to my amp not carrying power?
I just finished hooking up my amp and sub. Everything is correct. I have double and triple checked it all. At the battery terminal, the power wire has power. On both sides of the fuse, the wire has power. However, when I go to my amp (I even cut the wire open at the end to check), there is no power to the wire on the amp or inside the wiring jacket. Suggestions?
I really don't know anything about electronics, so if this is dumb, sorry.
Sidenote: I also don't have power to ground or remote (that's not what I'm worried about tho. I should still get power through a wire from the fuse to the back.)
Es esta una buena pregunta?
1 comentario
There is not enough information to properly respond to this question. For clarity, please post some pictures that can show what you are trying to describe. We should then be able to advise properly.
Thanks,
Dan
- de Abrsvc
