Saltar al contenido principal
El Super Nintendo Entertainment System (SNES), o simplemente Super Nintendo, es una consola de juegos de 16 bits lanzada por Nintendo en 1990. Super Nintendo fue uno de los más vendidos de su tiempo y todavía tiene una gran base de fans en la actualidad.
Preguntas 105 Ver todo
What is wrong with this SNES cartridge-connector?
My SNES has the following symptom: it boots up fine and somewhere between 1 minute and 30 minutes after booting the game it dies out and blackens. The duration after which it fails varies each time, it seems random. I've tried different games, but the problem holds so it must be the console. Once plugged in and booted, holding the game back (by pressing it towards the back continually), seems to work. I've opened up the console and found something that looks like damage to one of the connectors in the cartridge holder. Is anyone familiar with this problem? How can I solve it and does anybody know what kind of damage this can be?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Max Caspers lets see the “found something that looks like damage to one of the connectors in the cartridge holder. “. Post some images of what you see with your question so we can see this as well. Use this guide Agregar imágenes a una pregunta existente for that. Use these guides Super Nintendo Repair to work on your SNES
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
I've added the images
- de
Based upon what I can see, the connector needs to be replaced. You can get one here:
https://www.ebay.com/itm/Nintendo-NES-72...
Dan
- de
@abrsvc "I have replaced over 100 of these" hopefully you did not try to replace a 72 pin connector from a NES with the 62 pin connector from a SNES on those. Your link is once more to the wrong part.
Max Caspers make sure that your console is truly a SNES. It will require a 62 pin connector for replacement. There are 3 different connectors for the SNES so make sure you get the right one. They are available but a big harder to find so check ebay.com or alibaba.com for a suitable replacement. BTW you do realize that the replacement requires soldering.
- de
This sounds like the game connector is failing. This is a common failure. I have replaced over 100 of these in my career. The repair is relatively simple once access is gained. The replacement connector costs around $10-$12.
Dan
Puntuación 0
Añadir tu respuesta
Max Caspers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 37
Todo El Tiempo: 3,261
