Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Nikon D80 es una cámara digital de 10,2 megapíxeles con un solo objetivo que se lanzó al público en 2005. Está pensada para la toma y filmación de fotografías digitales.
Err Message/ Flash won't work
I have a Nikon D80. It won't take a picture on any setting and keeps showing an ERR message. THe flash will not pop up. Does anyone know what could be wrong with it? Or how to repair it?
Thank you!
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Does it only give you an error after you press the flash popup button?
If I remember correctly the mechanism is fully mechanical (the popup function that is). It may be because the flash is not poping up.
Did you drop it or anything?
- de
I will try that right now!..Thank you SO much for you advice!
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Gently push down on the top of the flash head and push the manual release button for the flash.The little hook that is holding the flash and is supposed to retract when you push the bottom to pop up the flash is probably stuck. Just a little explosion drawing, may help you out to see what is going on (hope I copied the right page:-) Good Luck
Imagen
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Dawn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 21
Todo El Tiempo: 9,669
