Hi @godric29085
Please confirm the model number of your laptop.
Water in contact with electronics is never good. You need to open the laptop and check if any damage has occurred.
It may not be evident straightaway, but unless you've been extremely lucky problems will start to occur in the days and weeks later.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the laptop's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
Do not continue to charge or to turn on your laptop and remove the battery as soon as possible to minimize any further damage.
Then you need to dis-assemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this it might possibly work correctly again. If not then the schematics and the service manual may be needed to try and fix any problems.
1 comentario
Hi,
Did you check for error LEDs as suggested or can you get into BIOS on startup?
- de jayeff
