Saltar al contenido principal
El primer smartphone de Huawei con el nuevo chip Kirin 970. Lanzado en noviembre de 2017.
Preguntas 17 Ver todo
My phone fell in water
My phone fell in water when im taking a shower. the speaker doesnt work properly. what should i do about it. it sounds cracky
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best
Desmontaje de Huawei Mate 10 Pro
Replacement speakers can be found here
Hope this helps
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
CharlieGraal Studio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 3,568
