Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías para reparación de cocinas y hornos eléctricos y a gas
Why do some of the buttons on my oven touch pad not work?
I have a Frigidaire brand gas oven with an electric range that has a touch pad used to control the oven (temperature, broiler, etc.). I got an f11 error with a constant beeping sound, so I tried unplugging and replugging it into the wall, which didn’t work. I then cleaned the contact points between the display layer with alcohol and now the beeping sound is gone and some of the buttons work, and others don’t (buttons #1-6, and a few others work, buttons such as “bake”, “broil”, “start”, “cancel”, and “set clock” do not). Why is this and how do I fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
4 comentarios
I have exact the same issues. None of my bottoms work now. Beep did go away. Digital timer still display. Did you find a solution?
- de
The panel and buttons don't light up do so I can't program my oven
- de
I also have an electric stove and oven with a digital pad that controls the oven. Worked fine yesterday. Went to use it today and none of the buttons on my control pad work. Stove does but not the oven.
- de
I had this happen also. All the touchpad buttons went blank. No clock display or anything. Overnight it seemed fix itself! I don't understand this. Everything came back as normal. I didn't do anything at all.
I
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
F11 is definitely a key stuck failure and I didn't require any parts to fix this.The cause of the problem is an over abundant use of double sided tape at the factory. I suspect that either heat or continued use of certain buttons causes the glue to weep into the button/contact pad causing the button to stick to the contact. On powering up our range showed PF and if you waited 10-15 secs without touching any keys F11 would display and and there was continuous beeping. I verified this was the case by removing the upper rear panel of the stove and disconnecting the keypad connector from the upper left of the lockout board. Then on powering up our range simply sat there showing PF. Of course you can't get past this with the keyboard disconnected anyway.The fix--- to make repair easier I removed the glass panel to which the keypad is stuck from the range. Pull off the burner knobs and you will find plastic nuts holding the glass panel to the metal housing. Remove the plastic nuts (make sure you let the keyboard connector go first by pulling the connector lock -small tabs on either side of the keyboard ribbon - towards you about 1/8". The ribbon cable will then slide right out.) Use a razor blade to gently work your way around the plastic trim bezel and remove the bezel. The keypad actually consists of three plastic sheets sandwiched together. You only need to remove the top 2 layers. Layer 1 is the printed keypad and layer 2 is the contact pad.You have to be careful in all this or you may crease or damage a panel. I started the edge with a razor blade and then stuck in the edge of a spatula. The idea is not to slide the spatula in but rather to insert it a small amount and lift. Slide it in a little more and lift. Just have a little patience and don't simply try and slide the spatula in or you may scrape the keypad and/or contact pad. While I suppose the more AR of us would then have to clean all the double sided tape off I simply cleaned up the keypads and matching contact pads. I stuck the whole thing back together and reattached the keyboard ribbon cable (hold it in place while pushing in the cable lock mentioned above. If you aren't too squeamish you can test the keypad while you have everything apart as follows: Connect the contact pad (this is the part with the ribbon cable attached) to the lockout board. Power up the stove. At PF touch one of the keypads to the stop/cancel contact pad. The PF should be cleared and you should be able to operate the oven by touching one of the keypads to appropriate contact pads.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Thanks for saying this! I tried doing this, which is what got some of the keys to work. Now I have about half of them that do work and half that don't.
- de
What's the model number?
- de
If you're still getting notifications on this post: I have a Samsung FE-R300 electric glass top stove. Some of the numbers work, some do not. Nor does the bottom row: clock, timer, etc. Do I follow the same instructions? Thanks
- de
I know this question is from a while ago, but hopefully my answer will save someone a few hundred dollars. My “start” button stopped working. I tried the popular fix of removing and cleaning the ribbon cable attached to the electric panel. That didn’t work. As a last ditch effort, I peeled back the front of the panel — it’s stuck on there with glue. I used an alcohol wipe to clean excess glue from the contacts. Works like a charm!
Imagen
Puntuación 0
3 comentarios:
OMG. Same happened to my oven. I am not a handy woman but I wanted brownies! Followed this suggestion and my brownies are now baking! Thank you!!!
- de
Did you only pull back the part by the button that was not working? I’m fearful to mess up other functions that are working but I need my lower oven for thanksgiving
- de
By "front of panel" do you mean you took off the panel from the front or is that something reached from the back?
- de
Añadir tu respuesta
Quintin Roper estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 29
Ultimos 30 días: 144
Todo El Tiempo: 43,526
