Saltar al contenido principal
La única version con Wi-Fi del Apple iPad 6, lanzada en marzo de 2018. Disponible con 32 y 128 GB de almacenamiento. Dispone de una pantalla Retina de 9.7 pulgadas y de un chip de fusión de 64 bits A10.
Preguntas 20 Ver todo
Can you replace the home button and still retain functionality?
Just looking to retain home button function, I am not concerned about retaining Touch ID.
If it can't this is going to push along of schools into paying for apple care.
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
3 Respuestas
Solución Elegida
Replacing the Home Button will not retain the TouchID functions but it will allow you to "push to click". If you want to change the HB yourself, check out this guide.
Fue útil esta respuesta?
Puntuación 5
2 comentarios:
That guide only tells you how to remove. I have found no documentation concerning home button function after replacment.
Just wanting to see if Apple pulled the same trick with the home button that they did with the iPhone 7 and 8.
- de
It's a physical actuator, just like all the iPhones before the iPhone 7. You can see it in the picture above (that little black dot in the middle of the button). So if you change the button, you maintain "push-to-click". The iPhone 7 has a solid state button which is why replacing it kills all functionality.
- de
Nathan,
On the iPad 6 if you replace the home button it will continue to work as a home button without Touch ID. The issue regarding the iPhone 7/8 was due to it being a solid state button, while the iPad 6 button actually physically moves.
I hope this helps,
Charlie B.
Source: 2 Years experience
Puntuación 2
1 comentario:
Do you mean after screen replacement with original home button still Touch ID will not work ?
- de
Puntuación 0
Añadir tu respuesta
Nathan Selby estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 4,422
